Page 8 of 8 FirstFirst ... 345678
Results 106 to 118 of 118
  1. #106
    Dec 2023
    Here is the post, im referring too. its number.
    https://www.digital-kaos.co.uk/forum...so#post3488248
  2. #107
    Dec 2023
    Quote Originally Posted by datahop View Post
    Now I feel dumb, thanks for the clarification
    Now I'm trying to figure out why the other digits are changing. I've downloaded the files on this thread https://www.digital-kaos.co.uk/forum...ight=mt09+2500 and compared them. Below in the red rectangles the ones that are changing and I don't understand why.
    Attachment 1003387
    Many thanks again
    Hi. Anyone? Is it because of the checksum? thanks!!
  3. #108
    dashradio's Avatar
    Inafield
    I would think it is because you have re-read after you have added a few miles on
  4. #109
    Bulgaria
    Default How calculate checksum for mileage in BSI Delphi 2016 > ?
    Hi, mates !
    Happy new year !
    BSI FL5 , car is 5008, 2017 , mileage 274949 km . Thank you for help to know !
  5. #110
    Dec 2023
    Kansei algorithm anyone? It's been asked before but no-one has posted it yet. Lots of calculators out there so it's fairly well known I suppose, but I've never seen the algo itself.
  6. #111
    Dec 2023
    Can anyone help explain the Denso Algo?
  7. #112
    Dufner
    Johnner's Avatar
    Éire
    Quote Originally Posted by bunty95 View Post
    Mate, I would look at learning hexadecimal first. No point in explaining the partial script that you see in that post
    There's more to that script
    Post up, as I asked for before, a particular file that you would like explained, and we'll try walk you through it
    Please don't post a script, as you obviously have no idea about where to even start with it
    In order to understand lines of code/script, start learning Object Oriented Programming also
    This will teach you all about functions, procedures, data types etc, so you will understand what is happening with the code
    J
  8. The Following 3 Users Say Thank You to Johnner For This Useful Post:
    bunty95 (8th January, 2024), dashradio (7th January, 2024), jomberykaso (7th January, 2024)
  9. #113
    Dec 2023
    My question is why is this below line used? I understand object oriented programming, just dont understand why there is a subtraction of FFFFFF. (Im assuming the $ indicated HEX?)
    n3 := $FFFFFFF - (n2);
  10. #114
    Dec 2023
    As an attempt to obfuscate the miles in the eeprom
  11. The Following User Says Thank You to dintech For This Useful Post:
  12. #115
    Dec 2023
    Thanks dintech.
    Does anyone have the full Denso algo, couldnt find it on the forum and want to understand more then the small bit i found?
  13. #116
    Apr 2020
    Can someone tell me how to calculate this one manually?
    Yamaha Aerox
    PIC16F1947
    76.987km
  14. #117
    Feb 2024
    Does anyone know Ford’s mileage formula?
    https://www.digital-kaos.co.uk/forum...adjust-mileage
  15. #118
    Apr 2024
    Can you tell me how to set up the display of km and degrees Celsius instead of Fahrenheit and miles on the dashboard of the Honda pilot 1? There is a firmware dump, I can edit it
