Results 1 to 4 of 4
    EU Romania
    Default VW Golf V 2006 Can gateway update from 1K0907530F to new version ?
    I have on VW Golf V 1.4 benzine from 2006 with original Can gateway with 1K0907530F 0120 and I need version 1K0907530R de SGO file and also 1K0907530F SGO file for back up.
    I made update from 1K0907530F 0120 to 1K0907530K 0178 and not work Brake 1, ABS, ESP and Air conditioner, for this reason I need original
    1K0907530F SGO if is posible and also 1K0907530R SGO file to see if is working ok with R.
    EU Romania
    I fix the problem, can close.
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by Seby_TM View Post
    How did you solved?
    Sent from my SM-J415F using Tapatalk
    EU Romania
    Quote Originally Posted by ASCM View Post
    How did you solved?
    If I remember correctly I clear all errors at diagnostic, after take out the -12V from battery for 5 minute after reconnect back -12v to battery, start the car and make diagnostic, see if I have the same error or not, clear all errors If some are present and after start car and make some drive, check the brake and Air conditioner if is working, normally need to work.
    After recheck at diagnostic if persist some errors, now not need to be present any error.
    In my case work in this way with success.
  5. The Following User Says Thank You to Seby_TM For This Useful Post:
    shadow1962 (18th April, 2021)
