Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
And it's possible to delete this error from the ECU? For ever?
What you have done to the ecu?
Try to find original to replace...( Post your ecu info....)
I only read the EE with IO terminal (only read don't wrote nothing) . I read in some forum that this sometimes happens and the only way is to
programe a diferent VIN in the ECU and after the right VIN again with the original diagnostic machine. The problem I don't have a original diagnostic machine. It's possible
delete the error for the immo light in dash torn off?
If you delete code will I/O correct checksum?
No I/0 don't correct checksum , can you correct ??
