TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
Tde97 (4th July, 2020)
Thank you!
I tested this file...but it runs pretty bad, pops and cut out during normal acceleration
(DEMON DEVELOPMENT)
Sjeesbeest (22nd March, 2021), Tde97 (4th July, 2020)
First tune
Launch is working ok!
But normal driving bad (cuts out) and nls also doesn't work right
I'll test this file now
Tested! Launch and NLS feels good
But normal driving and after a few pulls i get limp mode (max 0,3bar boost)
Stock Injectors
always logs and no problems
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Had no problems with the car it was tuned on but I'll do it from scratch instead of using that tune
(DEMON DEVELOPMENT)
Changed n75 valve, fuel pump, dump valve... no change
With Software from 1.8T AUQ 180hp it runs perfect
STG1
PASS IN PM
machokabra (10th July, 2020)
Thanks Antastra1989!!
Stage 2 AL NLS
I need it on this 1 if possible?
dale d (5th September, 2020)
