Upload photos but
GUESS MODE ON
brown =earth
black/yellow =brake
black/green. Black/white = trafficators
grey/red and grey/black = sidelights
white/black = reverse
GUESS MODE OFF
LOST INTRESTING MODE ON
Upload photos but
GUESS MODE ON
brown =earth
black/yellow =brake
GUESS MODE OFF
Thanks for the reply , but iam searching for something more detailed .
12 volts is not present on the UHC , citylights fault warning on screen , tail lights low voltage ..
Sounds like full of water
Do you think that the under hood unit replacement will solve the issue , i want to trace the lines back to the ECU
And without the schematic its almost impossible
Any help ??
With or Without REC?
constantinexx (29th June, 2020)
with please , tail and head light including the REC and UCH or any other related ways to ECU iam not sure..
thanks in advance
I don't know how well it is understood from the pictures. And I don't even know exactly if I hit the car's features, you were a bit poor in details.
I forgot the last explanation
its perfect , but for the tail lights the whole schematics ended by the Rear Electrical Center REC , further i canot trace them back any more to brake switch for examle.
what you did is perfect but if you can also provide that i will be grateful Sir, thanks alot
The information between UEC and REC is done in Digital, through CAN, only through the CAN bus ... analogically only the information from the brake switch is transmitted to REC.
Thanks alot , really helpful
The problem with the taillights generally occurs due to condensation in the REC, which begins to affect wiring and soldering. Inside the REC.
The REC module is very close to the rear wing, in winter this board is very cold and all the moisture in the car condenses on the cold parts, including the REC
constantinexx (9th July, 2020)
