Results 1 to 3 of 3
    McDowell's Avatar
    Feb 2019
    Zamunda
    Default Fiesta dahsboard indicator lights not working
    Hello mates,
    Iīve got the following dashboard with indicators lights not working in the dashboard, car ligthts are working fine. RefereNce is 6S6T-10849-CF
    I have compared flash memory with a correct one are both are exactly the same. Donīt know if problem could be on PCB or EEPROM data...PCB looks fine. I attached EE & FLASH readings.
    Thanks so much in advance.
    Aug 2016
    in the zone
    check if you getting 12v input to cluster plug when indicators are working. i had this same problem on hyundai and the earth cable to cluster was not fitted back after panel beating
  3. The Following User Says Thank You to sagie1zn For This Useful Post:
    McDowell (29th June, 2020)
    Aug 2018
    Romania
    The problem can also be in the Multifunction Control Module or in the jacks and wires between MCM and Instruments.
  5. The Following User Says Thank You to sebage For This Useful Post:
