Results 1 to 4 of 4
    Dec 2011
    Default PSA MED17.4 injector driver chip
    Hi, can anyone help to finding injector driver chip in MED17.4 MCU 1766.
    Have another ecu from citroen ds3 also med17.4 but dont know which one iti s
    Thanks in advance
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    It must be the square one....( Get a clear picture of the board)
    It is only a few chips.... Google it one by one and you find the right ....
    Dec 2011
    Hi thanks for answer, guessing is the 4 at the left bottom side
    Dec 2010
    You can do a continuity test from injector ECU pins to the legs, one leg will be a direct connection.
    If you want to find something smaller, you can use a metal brush connected to the multimeter over the board which can narrow your search.
