The file size and the file you provided is bad, make reading again... Also, if file good, check catalytic converter, I had one exactly with the same problem, turned out to be catalytic converter which was damaged internally - if you check front at end, it looks normal, but in the middle there was damage, you can try to shake it, should hear some sounds...
