Originally Posted by
diyre
Hello friends, I got a C-Max with a dash problem, flashing red light, does not start, strange things. Can-bus failures .....
It is the same picture and problem that the focus had.
Check soldering of the 32 pins, but it follows me with same problem. Check if there could be something weirder in it, but without success.
Did you have the typical problem with these paintings? to know a little guidance to keep looking for the fault.
Thank you very much
a greeting
Hello friends, I got a C-Max with a frame problem, flashing red light, does not start, strange things. Can-bus failures .....It is the same picture and problem that the focus had.Check soldering of the 32 pins, but it follows me with same problem. Check if there could be something weirder in it, but without success.Did you have the typical problem with these paintings? to know a little guidance to keep looking for the fault.Thank you very mucha greetingHello friends, I got a C-Max with a frame problem, flashing red light, does not start, strange things. Can-bus failures .....It is the same picture and problem that the focus had.Check soldering of the 32 pins, but it follows me with same problem. Check if there could be something weirder in it, but without success.Did you have the typical problem with these paintings? to know a little guidance to keep looking for the fault.Thank you very mucha greeting
