Results 1 to 11 of 11
    Sep 2018
    Default No DAB option in Mid-Speed Bus. Please help!
    I am trying to connect DAB45 to Blaupunkt CDC40 Opera on Astra H 2007, but when connect Opcom and go to Mid bus configuration in both the radio and display, there is no DAB option to set it to "Present".
    There are only:
    - EHU(Entertainment Head Unit),
    - DIS(Info Display TID,BID,GID,CID),
    - UHP(Mobile Phone Portal) and
    - ECC(Electronic Climate Control).
    I have tried to choose different car years and even Vectra C or Zafira, but still there is no DAB option.
    The op-com is genuine.
    Best regards!
    WALES
    Quote Originally Posted by unreax View Post
    There are only:
    Best regards!
    DAB is not supported in 2007
    wbr
    Sep 2018
    You mean that CAN bus of my Astra 2007 is not supporting DAB and I cant fit it to my car?
    WALES
    There isn't an OBDII tool with 2007 or before with DAB support....
    wbr
    Sep 2018
    So, is there a solution? Tech2?
    WALES
    Read POST#4 again......
    wbr
    carradio2001's Avatar
    France
    Only CDC40 Opera have DAB box. If you op-com and don't find it in MS CAN Bus then try another year or another car or change the interface or software !
    Carradio2001.
    WALES
    Quote Originally Posted by carradio2001 View Post
    Carradio2001.
    You think this works??? it's 2007 car NOT 2014
    wbr
    Sep 2018
    I have tried several opcom versions, but same.
    I also tried to open EHU options in opcom as Vectra, Zafira from 2003 to 2008 and still the same result. No DAB option in MID-BUS.
    shooting, there is Vectra C from 2004 and 2005, factory fitted with this CDC40 + DAB so I am thinking it should be possible to connect it somehow.
    WALES
    Do you own a Vectra?
    wbr
    Sep 2018
    Okay, got it.
    Thanks for the information!
    Best regards!
