HELP DUMP FOR 93C56 RENAULT ESPACE
Results 1 to 3 of 3
    McDowell's Avatar
    Feb 2019
    Zamunda
    Default HELP DUMP FOR 93C56 RENAULT ESPACE
    Hello mates,
    I´ve got the follwoing dashboard with the right hand clock,temperature,etc display dim dark...the rest is working just fine comsumption around 1.2Amps.
    I swapped the full display with a working one and still the same, resoldered resistors and change mosfet.
    I am attaching 93C56 readings, could you please check if it comes for bad dumps?
    Thanks a lot!
    Mar 2016
    Hi!
    Have you fixed this dash have same problem
    Apr 2020
    Hungary
    Sry , but first: IF you have Tuner list radio, then it will not work. TheTuner list communicate ONLY in I2C.. Update list, cabasse and all other radio-s are in CAN communication. Try to change radio first, then check dashboard. OR you can check with can clip.
    Sry for bad english, I didn't use English about 15-20 years ago..
