Please nobody knows anything , i am impressed
Hello guys i need your opinion on something
i am quite inexperiensed about the FEC/SWAP things .
i have a skoda karoc, Recently i installed the Levers for acc into the steering wheel , and i had to code the front radar for ACC
A coder abroad , coded my car remotly with ODIS, He flashed the Front radar 13 did some adaptations. And ACC works just fine , tested and is Perfect..
BUT i scanned the car and i saw
Front Radar 13 Error
762560 - Component Protection
U1114 00 [009] - GFA key
the response is that the job is done and he got nothing else to do .
radar is 2Q0907572 , MRR it was working as a front assist in car from factory .
in a short investigation i found that , there are two types of ACC activation
1.Hacked
2.Code generated
the thing is that the cost of activation (hacked) was little less than the others offered (code generated with no CP)
and i dont know what i will encounter into dealer after this
i feel little bit like scammed do i have to feel like that. or is it a normal operation and i do not have anything to worry about??
definetely hacked, don't use it, just time wastigating because of anytime it can be deactivate and It can make the you accident
did you figure out something? if yes what?
