    rob h's Avatar
    May 2011
    Default FRM3 vvdiprog fix not working
    Hello guys,
    Frm3, with short fail.
    009CBB short
    00A8BC (For some reason, it mixing up left with right)
    I could not get a D-flash reading with vvdiprog.
    And could not define partitions.
    So i read d-flash with Upa.
    For some reason, i did not work, dtc remained.
    Can i simply press erase, D-flash?
    FRM3.rar
    E89 E9x LED XE
    FRM3R PL2
    6135 9249084 02
    9249091
    Dec 2010
    FRM fix is for a dead module.
    To reset short circuits, you need tool32.
    You can't read D flash because it doesn't exist, it is used as the eeprom.
  3. The Following User Says Thank You to Morette For This Useful Post:
    rob h (2nd July, 2020)
    rob h's Avatar
    May 2011
    Thanks,
    Figured it would cure all that whas wrong.
    They tried it with tool32, and this time it did not work.
    So what option do we have to restore this module?
    Or is there a internal faulth in the Hw itself?
    Dont have a spare unit to test this data.
    bearheroes's Avatar
    Dec 2011
    They probably don’t know how to do it. The only solution is tool32
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  6. The Following User Says Thank You to bearheroes For This Useful Post:
    rob h (4th July, 2020)
    reproteq's Avatar
    en algún lugar de España
    with upa
    emulated eep partition dflash , 16, 0 , create
    emulated eep erase and program this file
    tanks + reputation
  8. #6
    rob h's Avatar
    May 2011
    This file, eeprom-fix, is the exact same as have posted in my folder.
    So thanks for the effort, but it is not helping me.
    If anything, then a confirmed health check, of the p-flash.
    Or a healty donor p-flash.
    Dont know, how this module works, guessing, if there is a tool32 obd option, it is in the p-flash.
    However 2 seperate guys tried fixing it with the tool32 allready.
    If the ee is fine, this leaves p-flash, or hw internal damage.
