    Timisoara
    Default Tiguan dash 5n0920 883c
    Hello
    i have this tiguan from 2014
    dash 5n0920 883c
    what tool can read immo data from it
    vvdi say no key stored in it keyless sytem is wotking car start
    vvdi identification of dash as VDO NEC 2009+ UDS
    car is key-less go and entry
    Thank you
    Oct 2016
    Slovakia
    VVDI reads this dash
    Attach the key to the ignition coil
  3. The Following User Says Thank You to jokir For This Useful Post:
    clauberty (6th July, 2020)
    Team dz's Avatar
    Apr 2017
    ALGERIA
    Smok - x-Tool
    read it
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  5. The Following User Says Thank You to Team dz For This Useful Post:
  6. #4
    team dz
    not copy paste my signature
    thamks
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
    Timisoara
    Quote Originally Posted by jokir View Post
    when i tray to read with vvdi it say no key stored in dash with key in ring
    key is ok i can switch ignition on and unlock elv with key-less go function
    i remove key battery and put key in ring and the same ignition and elev is working
  8. #6
    Oct 2014
    Netherlands
    If your problem persists, simply write service eeprom to cluster first. Write FF's to 12A0-14FF.
    Then you should be able to connect, and write original eeprom back to cluster as first work! Then do your stuff.
  9. The Following User Says Thank You to H2Deetoo For This Useful Post:
    clauberty (7th July, 2020)
