Hello,
I have here Peugeot 307 with BSI problem water inside.
I got other used BSI with same partnumber and read Processor to write on used BSI.
BSI partnumber is 9644098280
I am not sure if file is good or corrupted. Because BSI had water and weak battery for long time.
Can someone check if file is good or corrupted ?
If possible what is PIN code ?
Thanks for your help
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
aqua_life (2nd July, 2020)
Thank you for Pin Code.
I program BSI with code NQA4 and also tried 4AQN.
With BSI virgin it accepts Pin and VIN.
However to program the original car keys it always fail. Using Lexia and tried with FVDI too.
Car has 2 original keys and both read fine on Zedbull.
So, I try that maybe BSI that came with car was not original.
Engine ECU was never opened and is EDC16C3 0281010390
Attached is eeprom.
Can someone tell me Pin Code of this ECU ?
your pin is NQA4
good day
i need help find pin this ecu peugeot
edc16c3
0281010390
your pin JWK5 or 5KWJ ..........
doctorelectrical (23rd September, 2020)
