Results 1 to 15 of 18
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Default Rover 5AS remote programming t300+
    Hi mates. I try to program remote in rover 25, SCU 5AS system, i have t300+, but i can't comunicate with 5AS unit.
    I see there is a cable for Rover to comunicate with 5AS or MEMS (ecu). Any have pinout to do this cable? I can comunicate with MEMS throug pin 2 of T300 to pin 7 (K-line), but i can't comunicate with SCU unit.
    Thanks in advance.
    scotland clydebank
    Better buy cable not expensive and made in UK.
    p1et's Avatar
    Oct 2013
    What year of that Rover 25?
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by ruffles1986 View Post
    Thanks in advance.
    Here the diagram to make your own cable.
  5. The Following User Says Thank You to lion0304 For This Useful Post:
    ruffles1986 (3rd July, 2020)
    Sep 2011
    In the Garage
    Yes i saw also, but take some days to arrive
    Sep 2011
    In the Garage
    From 2000 year
    p1et's Avatar
    Oct 2013
    First time I hear about such cable. If car have OBD2 socket then SBB should do it - I never failed.
  9. The Following User Says Thank You to p1et For This Useful Post:
    ruffles1986 (14th July, 2020)
  10. #8
    scotland clydebank
    Cable has been around for several years
    A company called techtronics in UK made them and there is a big write up on this forum plus Internet about it never used sbb myself but if works as you said cheap tool to use.
  11. #9
    Sep 2011
    In the Garage
    I try with t300+ and diagram for rover and doesn't work, i thinks is problem of the crap of machine, i buy only for this car and dont work.... Theres is a way to read code of remote? then maybe i can add to 5as module directly as Pektron system
  12. #10
    p1et's Avatar
    Oct 2013
    So this is pektron or what?
  13. #11
    Sep 2011
    In the Garage
    Quote Originally Posted by p1et View Post
    This is a 5as system. For pektron i have solution by eeprom.
    And for 5as if i can read code from remote maybe can add directly to module 5as.
  14. #12
    fred77's Avatar
    Jun 2019
    Hmmmm very old 3 pin cable existed.
    Also i heard odd ground missing on OBD connector.
    But i think i know what u mean.,,,
    Separate rx n tx Comms on OBD pin 1 and 3 from memory and indeed separate OBD lead also exists. Recall writing software for it
    I have it - but sadly my original AD100 burned years ago and these clones aren't the same.
    PS. Don't rule out issue with car as most down scrap yard
  15. #13
    Sep 2011
    In the Garage
    SBB Clone work, solved!
  16. The Following User Says Thank You to ruffles1986 For This Useful Post:
    p1et (14th July, 2020)
  17. #14
    p1et's Avatar
    Oct 2013
    I told you
    That's why I completely do not understand idea of that 'special' cable...
  18. #15
    Jul 2015
    I told you
    AD100 doesn't have a built in multiplexer for that purpose. That's all.
