Results 1 to 10 of 10
    Jun 2020
    Default HOW TO TUNE A AUDI A3 2.O TDI 2006
    Hi, Please could some one give me some help, i have kess v2 but it does not read the ecu. i tried vagcom with a fdi chip cable did not read the ecu. What do i need to read the obd, cheers
    May 2019
    Normal read without problems 2006 but some edc16u1 i have read problem too. only bdm
    Jun 2020
    Thank you for the reply, i have never done bdm
    Jul 2018
    i read many u1 but write is a problem sometimes, bdm is best option for that ecu ..
    if you want cheap and obd solution, try mpps, hes gonna do that ..
    Jun 2020
    thank you alme94 i will try the mpps cable do you recommended getting it from ebay.
    Jul 2018
    i get mine from ebay so .. i think it will be okay ..
    but
    i suggest you also to try fix your kess bug because kess can read that ecu .. which fw and sw is your kess and ksuite ? do you try read from protocol ?
    Jun 2020
    Hi, alme94 ksuite 1.85 no idea what fw and sw. car protocol for the audi is listed but will not respond. MPPS cable arrived to will test on Wednesday.
    Jul 2018
    try with ksuite 2.47 and fw 5.017
    Jun 2020
    Quote Originally Posted by alme94 View Post
    I tried the mpps cable it said there was a security message, it allowed me to view the ecu details but would not read. Any advice please.
    Jul 2018
    vcds > engine > security access > type 12233
    unplug vcds
    dont turn off ignition
    plug mpps, try read
