delete the synchronization data and program ecm again. in the instructions for the emulator there is information about the location of the sync data in the dump
davorOS (3rd July, 2020)
thank you
do you delete only 6 bytes as emulator or full row 12 bytes in dump location?
this is dump from original ecu
problem with car is that dealer programme new bcm after keyprograming failer,so now car have new BCM and key,car crank but no start
this is why we are trying to do immo off or reprogramme old ecu to accept bcm
why the dealer did not do all the work so that the car would be in order? I am surprised by these actions
customer would have to buy all parts,ecu,bcm,elv and keys
but it is off budget for customer,so they try to order only BCM and key,so it is programmed but ECU didn't accept new BCM
could be that it need to have new set but also could be that wrong configuration is programmed and programing didn't go as planed
I'm not sure does it really need new set ,or they just didn't know how to programe new bcm in correct way
A working ecm should have been programmed in the car if it was working and was connected during the replacement of bcm.
That whose my opinion also but after trying coding bcm this is what dealer told customer
replace everything.........and pay €€€€
I will try to code it today
HERE VIRGIN FILE
https://we.tl/t-AK1KoNoe7a
pass after thanks + rep
I always fear third-party download links. digital does not prohibit rar loading. you can attach rar to the theme. If your file is useful you will receive thanks and reputation. but to demand this before no one has used your work and is not convinced of its reliability, your message will not be approved.
bearheroes (4th July, 2020), davorOS (4th July, 2020)
