Check BSM in engine bay
Peugeot Bipper 2010 no power on the ignition switch and when I turn switch ON no lights on the dash
When I connect external 12V to the switch all is OK
All fuses are OK - Can someone tell me from where comming originaly 12V on the switch - Front fusebox or BCM fusebox that is under the dash?
if someone can share wiring diagram will be easy to find
Manta1600 (4th July, 2020)
lion0304 (5th July, 2020)
Unbelivable... someone needs a spare fuse ?
Polak, wegier dwa bratanki i do szabli i do szklanki
sounds more like someone creating a fault to check how quick it is found:0
No mistery
the van comming from auction and this is the common problem with cars from auctions
Oh yeah, in this case, you need to be ready for all. I alway ask customer car's history before they contact me.
In this case I was confused because fuse F3 is described - Starter motor supply
Usually fuses related to the ignition are described - IGN
The worst case that I had with auction car was VW Polo with 2 missing fuses for the engine ECU - Itried with one fuse to put on all empty positions but car wont start
I decied that the ECU is faulty and bought ECU kit - The same situation car won't start and after that I striped the fuse box to see that 2 fuses are missing
On this polo 6R when you look the fuse box some slots looks like they has only one metal connector
had this many times with local bca was common for punters to induce faults hoping to get vehicles as non runners, same with service records suddenly being found behind glove boxes ... .
