Results 1 to 9 of 9
    Mar 2018
    UK
    Default Peugeot Bipper no power on the ignition
    Peugeot Bipper 2010 no power on the ignition switch and when I turn switch ON no lights on the dash
    When I connect external 12V to the switch all is OK
    All fuses are OK - Can someone tell me from where comming originaly 12V on the switch - Front fusebox or BCM fusebox that is under the dash?
    if someone can share wiring diagram will be easy to find
    lion0304's Avatar
    Oct 2014
    Check BSM in engine bay
  3. The Following User Says Thank You to lion0304 For This Useful Post:
    Manta1600 (4th July, 2020)
    Mar 2018
    UK
    Quote Originally Posted by lion0304 View Post
    Thanks - fuse F03 was missing
  5. The Following User Says Thank You to Manta1600 For This Useful Post:
    lion0304 (5th July, 2020)
  6. #4
    szkeptmen's Avatar
    Hungary
    Unbelivable... someone needs a spare fuse ?
    Polak, wegier dwa bratanki i do szabli i do szklanki
    Dec 2016
    central uk
    sounds more like someone creating a fault to check how quick it is found:0
  8. #6
    Mar 2018
    UK
    No mistery
    the van comming from auction and this is the common problem with cars from auctions
  9. #7
    lion0304's Avatar
    Oct 2014
    Oh yeah, in this case, you need to be ready for all. I alway ask customer car's history before they contact me.
  10. #8
    Mar 2018
    UK
    In this case I was confused because fuse F3 is described - Starter motor supply
    Usually fuses related to the ignition are described - IGN
    The worst case that I had with auction car was VW Polo with 2 missing fuses for the engine ECU - Itried with one fuse to put on all empty positions but car wont start
    I decied that the ECU is faulty and bought ECU kit - The same situation car won't start and after that I striped the fuse box to see that 2 fuses are missing
    On this polo 6R when you look the fuse box some slots looks like they has only one metal connector
  11. #9
    Dec 2016
    central uk
    had this many times with local bca was common for punters to induce faults hoping to get vehicles as non runners, same with service records suddenly being found behind glove boxes ... .
