Page 13 of 23 FirstFirst ... 389101112131415161718 ... LastLast
Results 181 to 195 of 341
  1. #181
    Quote Originally Posted by innovateq View Post
    Hi here!
    I need to do some work with a John Deere engine, but have no info about it.... The engine doesn't start.
    Can anyone help me with the wiring diagram and all info available for this engine?
    Engine:
    6125HF070
    RG6125HF060810
    ECU:
    John Deere L6 /12V
    P/N: RE507982
    S/N: 103096
    Regards!!
    what machine is it in,eg artic tractor/combine?i have all the manuals
    thanks clive
  2. #182
    Top Poster innovateq's Avatar
    Palestine
    Quote Originally Posted by clivehanley View Post
    thanks clive
    Hi Clive!
    This is an Generator set.
    Regards!!
  3. #183
    Palestine
    Hi Clive!
    Regards!!
    I think it appears as a John Deere OEM engine with John Deere ECU (There is another version with other ECU, non John Deere).
    It is a 12.5 L engine
  4. #184
    Quote Originally Posted by DB_member View Post
    Thanks for your info on the different versions and good to know it runs under VMWare too. The version I installed was not happy about XP SP3, XP SP2 was OK but I never tried Windows 7 or others. Perhaps your SW release is more fresh and runs on SP3 too.
    I'd like to add that at this forum everything is free (anyone trying to sell something gets banned immediately).
    Some of us are doing this out of curiosity, not for business and (specifically) then a free approach is reasonable, for many of us the only option.
    Can you comment more about the diagnostic adapter, most that I've seen are too costly unless used for business.
    if your doing this just for curiosity the just ask your dealer, thet are useally helpful, the jd daignostic works in detail
  5. #185
    Dec 2010
    Srbobran, Serbia
    where to find AGHIST_EN_2008 dvd ?
    thank`s!
  6. #186
    Senior Member colh's Avatar
    [QUOTE=pwdiesel;858940]I found the same thing when install failed. I look at text file of install and said it failed for unapproved OS which it then skipped without ask. Found SA setup.exe and it then asked if I wanted to install on Uapproved OS. No problem then, just had to set date back to 2/2008 so it will run under 30day licence.
    Still could use a key for my ID if someone would be so kind
    ID 0016CB960A1760328572[/QUOTE
    PW try this and see PM
  7. #187
    Dec 2010
    I just paid JD Dealer $1800 for 2011 updates no Ag and local dealer will not sell me ag software. Thanks for the help here!!
  8. #188
    California USA
    Quote Originally Posted by gundamknt View Post
    Only 700.00 a year here from JD.
  9. #189
    Dec 2010
    Srbobran, Serbia
    who have Service Adviser 2.8.3 or new to share?
  10. #190
    Oct 2008
    Did anyone ever successfully use the service advisor software with a regular Nexiq USB-Link ?
    There were earlier posts about thsi but nobody followed up on it.
  11. #191
    California USA
    Quote Originally Posted by eamonn1110 View Post
    I have the both the adapter (usb-link) and the program, but no buses or the time to go test it out any time soon.
    Heard that it doesn't work tho.
  12. #192
    Sep 2010
    Anyone has the Construction data DVDs?
  13. #193
    Hello guys ..
    Anyone has the data discs for John deere service advisor 2008
    AGHIST_EN_200801_01
    AGHIST_EN_200801_02
    AGHIST_EN_200801_03
    AGHIST_EN_200801_04
    AGHIST_EN_200801_05
    thanks in advance ..
    Regrads
  14. #194
    Dec 2010
    Quote Originally Posted by djovic View Post
    ..i have jhon deere S.A. 2.8.3. 2010......real
  15. #195
    Quote Originally Posted by ramirez2 View Post
    SO can you share it ??
    regrads
