Results 1 to 9 of 9
    Sep 2015
    Default Renault Laguna 2 2.0T 163hp, ECU pinout, SAGEM S2000RPMT
    Hi, I'm looking for pin descriptions for the Renault Laguna 2 2.0T (163HP) engine driver - Sagem S2000RPMT
    I am from Poland, thank you for Your help.
    May 2020
    hello,VIN number please...i will hep you
    Sep 2015
    VIN: VF1BG0S0629649052
    May 2020
    LAGUNA.ziphello,here the diagram and fuses,also a document for components
  5. The Following User Says Thank You to JETRONIC1 For This Useful Post:
    poprostuandi (13th July, 2020)
    Sep 2015
    Thank you! Do you have an reporg file in English?
    May 2020
  8. The Following User Says Thank You to JETRONIC1 For This Useful Post:
  9. #7
    Sep 2015
    Thank you so much, you helped me!
  10. #8
    Apr 2013
    Thank you so much, you helped mp
  11. #9
    Apr 2023
    Hi - a small thread revive.
    I have heard that in order to flash a new map to the ECU you need to remove the EEPROM and program it outside the ECU - is that correct?
