Results 1 to 8 of 8
    Jan 2016
    Default VW T5.2 Tachograph remove... help
    Hello
    Anybody can say how to remove the tachograph from t5.2 cluster?
    brend's Avatar
    Oct 2015
    Same where
    For quik answer load dump!
    Aug 2018
    Romania
    Have you tried removing the plugs from the tachograph and programming the instruments without a tachograph with VCDS?
    Jan 2016
    no.. i´m searching in the internet and all have problems with this simple programming... so i need a working solution
    Jan 2016
    in the next 30 minutes i can send file
    Aug 2018
    Romania
    I did some such operations on T5 from 2007-2009 and everything was simple and very ok.
    Jan 2016
    car is from 2012
    Sep 2013
    Hello I have similar problem with UDS cluster 7E0920870A, additional coding for speed source need login code
