hi you dead modul ? or you have diagnostic
i am have 7pp907279cf can read dump how you to want
Hello, thank you for your message..my problem is that the rear BCM lost stock program after trying to do the online programming,
they did it bad! before all was good only had a problem with the front BCM because my electric steering pump not working.
Now I can start the car but the rear BCM click with hazard lights. I have the front dump.
The rear BCM have the MC9S12XEG384 2M25j and I don't have the original D-flash.
Thank you for your help.
The rear & front BCM should have the same Dflash? Thank You in advance.
hi 7pp907279cf have 3m25j mask and have 7pp907279n have your mask give dflash
hi sterling lock work now ?
bcm read now vvdi -prog 7pp907279n
Orni777 (20th October, 2022)
Hi Szajsung..Thank you for your help. till now I didn't solve the problem of the Electric steering pump!
the 3m25j is not the same because mine have 384kb and 16kb for the d-flash.
799907279n have 16kb d-flash but the archive file is not working.
Thank You I appreciate your help.
7pp907279n have mask 2m25j you programing piwis 2 ?
Yes i have piwis 2..but how to make front bcm to recognize the rear bcm?
Bro.can you help me for password.regards
