Results 1 to 15 of 28
    Oct 2018
    Northern Ireland
    Default 2011 Range Rover Vogue KVM corrupted
    Would anyone have repair files or be able to help with this ?
    Read with Autohex but corrupted flash so original key proxy function and start not working
    Any help would be appreciated
    Thank you 👍🏻
    You have chosen one of the worst thing for this. It only does unsecured MCU but not sure if properly. Flash it with SDD it dont need to be done on bench at all.
  3. The Following User Says Thank You to qwojtus For This Useful Post:
    Jimmy07 (7th July, 2020)
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    part no and flash id etc will need to be posted
  5. The Following User Says Thank You to whiskeyman For This Useful Post:
  6. #4
    Oct 2018
    Northern Ireland
    Thanks for replies 👍🏻
    Sent it to a guy last week I think he’s managed to fix corrupted files and has added key
    I’ll keep you posted hopefully it works
    electromech's Avatar
    Behind a large rock
    Quote Originally Posted by Jimmy07 View Post
    Thank you 
    So was this a user error or Hexprog error as they claiming it better than any other unit on the market?
  8. #6
    Quote Originally Posted by electromech View Post
    They claim a lot. Read secure KVM FK72 with Hexprog and you will see.
  9. #7
    Feb 2018
    Glasgow area
    Very unlucky to find a locked 2011. Only one I've seen was stolen from a dealership and had new module fitted when recovered.
  10. #8
    Oct 2018
    Northern Ireland
    ACDP or prog from now on lesson learnt the hard way
  11. #9
    Oct 2018
    Northern Ireland
    This KVM has scratches around the lugs where you open casing so someone has been at it before. Saying that original key worked, when file was read with Autohex said files read ok but they were corrupted unfortunately
  12. #10
    Feb 2018
    Glasgow area
    ACDP does these well in my experience.
  13. #11
    Oct 2018
    Northern Ireland
    Done a few with no glitches ACDP
    Stupidly tried Autohex to see and world of shit
  14. #12
    lion0304's Avatar
    Oct 2014
    When i want to test new tool, i have to spent a little time by using the tested, safe tool to make backup.
    Then next i can use new tool to test. We learn almost every days and by many way.
  15. #13
    Oct 2018
    Northern Ireland
    Autohex support response after telling them it corrupted D flash and wrote Eprom off “Yes this can happen sometimes”
    WTF Autohex if it damages KVM units take it off your software application you idiots
  16. The Following User Says Thank You to Jimmy07 For This Useful Post:
    fred77 (8th July, 2020)
  17. #14
    fred77's Avatar
    Jun 2019
    Interesting...
    Assume Autohex BMW ?
    Wouldn't of tried myself n kept for BMW but sure if listed then wrong of em.
    I've killed 2 KVM units - one with Abrites 2015 with FK72 and another older one doing 2012 backup (my old van having key cuttings blow on to circuit).
    Really recommend JLR SDD - should be the one and only tool on these unless module is locked in 2015+ modules.
    Don't listen to people tell u the earlier ones are locked with MC9S12XET256
    And will add XEP100 works well on these. VVDI Prog have to remove crystal - pretty sure the crap had was caused by that.
    Companies r quick to sell the kit but each has pros/cons/down right bugs
    Plus one more thing, recommend to everybody 14V supply. Bugger 12V
  18. The Following 2 Users Say Thank You to fred77 For This Useful Post:
    Jimmy07 (9th July, 2020), vialli (9th July, 2020)
  19. #15
    Oct 2018
    Northern Ireland
    Fixed now but another issue
    Battery support put on as battery was low. Car started with original and new key working. When support taken off smoke coming from battery area and battery light on dash.
    After running scan it has burnt out battery charging module. This is attached to earth battery lead. New lead and attached module £120 from dealership
    Never attach support direct to battery
    Live on battery and earth MUST go to body or this is the result .....
  20. The Following 3 Users Say Thank You to Jimmy07 For This Useful Post:
    electromech (10th July, 2020), Fallen (3rd July, 2021), fred77 (13th August, 2020)
