1.Open the ECU - no damage inside.
- charge the battery, ecu installed back - clear all codes - engine crancks well but no engine start and no new fault codes were stored.
-replaced CR pump and R/H fuel rail ( with the fuel pressure regulator ) feeded the pump with fuel gravitationally - fuel pressure 7 bar initially then 120 and 300 bar in fuel rail while engine crancks /when stop crancking the fuel pressure drops to 0 bar (all fuel goes out from the rail return line )
2. - Need wiring diagrams for the fuel system (fuel tank pump - ecu - relay) AUDI Q7 3.0L V6 TDI ENGINE CODE: BUG .
- Need procedure for removal/installation of the engine
- Need timing procedure for this engine ( not from autodata om if possible).
