Renault Clio4 2017
Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    Dec 2010
    Default Renault Clio4 2017
    Attached is a file from Renault Clio dash with S912XHY256 that i read using my UUPROG-S.
    Now it is 103084km and i need it to be 78200km.
    I know it is synchronized with the ABS, but i disconnected the ABS connector just to see the number in the dash.
    Thanks for your kind help.
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by junmab View Post
    here is your file...
  3. The Following 2 Users Say Thank You to drpeter For This Useful Post:
    junmab (7th July, 2020), t-ortman (14th January, 2022)
    Dec 2010
    Thank you drpeter. I checked in the car (without the ABS) and i have exactly 78200.
    Next step is to take out the ABS from the car...
    Oct 2019
    what will happen when you change the mileage on dash and connect the abs connector, will it synchronize again to old value ?
  6. #5
    Dec 2010
    armo, i tried that and it jumped to value stored in the abs after i drove it for 2 km.
    When i just connected it to the car it didn't jump.
  7. #6
    drpeter's Avatar
    Dec 2009
    The Netherlands
    you can disable the sync in the dflash of the PFLASH of the instrument cluster.
  8. The Following User Says Thank You to drpeter For This Useful Post:
    junmab (10th July, 2020)
  9. #7
    Oct 2019
    Quote Originally Posted by drpeter View Post
    dflash is something else then dump right?
  10. #8
    Dec 2010
    What do you mean saying "in the dflash of the pflash" ?
    Aren't they 2 areas in the FLASH of the mcu that were actually defined differently:
    One is used for the program and the smaller one is used for data (I think of it as emulate an eeprom area).
    Please correct me if i was wrong.
  11. #9
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Sorry i was drunk when i wrote that, d flash means dataflash (where the km vin etc is stored), pflash means program flash, this data is the main software for the dash, in the pflash you can disable the sync. You can read the dflash and pflash seperate with the right programmer. Or read by obd.
  12. The Following 2 Users Say Thank You to drpeter For This Useful Post:
    junmab (12th July, 2020), spantor (12th July, 2020)
  13. #10
    Dec 2010
    I took out the ABS but i can not find any EEPROM at the back of the ABS. Could it be at the other side ?
    It is a BOSCH ABS.
    Attached some pictures.
    Need your help please.
  14. #11
    Jan 2012
    Germany
    Very interesting information, with what tools could you separate pflash and dflash?
    Another question Would it be possible to run the dashboard program with upa clone?
  15. #12
    Dec 2010
    Quote Originally Posted by spantor View Post
    I am using UUSP-S for the cluster. It has seperate options to read the P-flash and D-flash.
  16. The Following User Says Thank You to junmab For This Useful Post:
  17. #13
    Jan 2012
    Germany
    Clone work fine?
  18. #14
    Jan 2012
    Germany
    It is a BOSCH ABS.
    Finally find eeprom?
  19. #15
    Dec 2010
    Nop. No one gave me any advise, and i am still waiting for help from this forum.
