Results 1 to 12 of 12
    Jun 2017
    Minsk
    Default Honda Civic 77960-TGG-A020-M2
    HelloPlease help me remove CRASH.Honda Civic 77960-TGG-A020-M2.Thank.Thank.
    Feb 2017
    CLEARED BY RONNIE.rar
    TEST AND REPLAY }
    PASS IN PM
  3. The Following User Says Thank You to Ronnie123 For This Useful Post:
    mrandrerio (9th July, 2020)
    Jun 2017
    Minsk
    Good afternoon. Thank you. There is no error on the Airbag. It is impossible to calibrate the ABS. ESP, BRAKE, EPS is lit on the panel.
    Feb 2017
    Airbag problem solved.
    you have another problem in ABS system.
    Do a system search, and post here the dtc. we may help
  6. #5
    Jun 2017
    Minsk
    Thank you. On Monday I will look for an ABS malfunction.
  7. #6
    Jun 2017
    Minsk
    Hi. There are problems with the dump. I fill in the native dump and the ABS calibrations pass, but the calibrations do not pass with your dump.
  8. #7
    Jun 2017
    Minsk
    Please help to clear Crash
  9. #8
    Jun 2017
    Minsk
    Thank you all. The question has been resolved. I had to clean the dump again. If someone needs a clean dump, write.
  10. The Following User Says Thank You to mrandrerio For This Useful Post:
    Hondasilver (6th March, 2021)
  11. #9
    Apr 2010
    I need a clean dump, can you help me? please
    Thanks a lot
  12. #10
    tazz75's Avatar
    Nov 2018
    11 years no one thanked..and you'r newbie....really ? I would be ashamed.........
  13. The Following User Says Thank You to tazz75 For This Useful Post:
    dmka (20th February, 2021)
  14. #11
    Mar 2015
    can you send me the whole clear dump pls
  15. #12
    Apr 2020
    Toronto, Canada
    Can you send me the whole clean dump please.
    Thank you .
