Results 1 to 2 of 2
Thread: audi tt
    sv2hqx's Avatar
    Jun 2014
    Default audi tt
    hello
    i received a dash with temperature always on 90+ Celsius
    on car or on bench same
    on car if engine is warm temp show over red mark
    software??
    Dec 2016
    central uk
    if everything else works on dash i would try with power off resetting the needle to its rest position. ( remove power and then remove needle then power on bench and reset neele to just below the 50 mark approx 5milimetres, or the same as the fuel gauge drops too).
    then power up and make sure it starts to move.
    it was common on these to have the needles trapped or moved when replacing the front panel.
    worth a try
