Tempus Omnia Revelat
This is the video, when Hexprog has killed BCM 911 2017 first time. It sometimes wipe off the data during unlocking the chip. Always read the right flash but Data does not exist anymore. You can argue and say how many thousands you have done successfully, but this is the real fact and you may experience it one day.
Porsche BCM 1N35H Hexprog - YouTube
tepSIJA (20th January, 2023)
greetings, I didn't mean to argue or speak from my experience for hex prog at all. I am in the process of buying hexprog for the sake of many others for which I will serve as a programmer. I have a colleague who works regularly with porsche bcm with hexprog and he never had a problem. but as you say until once. thanks for the video and info anyway
I had and used hex prog until one year ago, then I sold it after a short time. I didn't have the opportunity to do Porsche with them, but now that my business has expanded and I have a demand for Porsche keys, I'm buying it again. hexprog most used for cas3 and cas4 reading. Now needed for porsche because my opinion is safest for porsche bcm
That is true, I used vvdi prog but it didnt work for Porsche BCM mask 2m25j so I bought hexprog and it worked perfect. Because of that I 100% don't trust VVDI Prog although it worked for every CAS4 I worked on so for CAS it's okay if you know what you doing and have soldering skills, however with Porsche you're playing with fire.
Yes it's not uncommon to hear somebody brick Porsche BCM with VVDI Prog, however most of the times it's user fault, poor soldering and desoldering skills. And last thing you want is to tell Porsche owner that he can't drive anymore...
go day friends pls i have porsche bcm the pfile is bad pls who can asistance with it
mask 2M25J
