Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 63
  1. #46
    Quote Originally Posted by Fallen View Post
    Here you go
    sir the car starts and drops after 30 secos
    pls i needhelp
  2. #47
    Fallen's Avatar
    Quote Originally Posted by nokwueze View Post
    pls i needhelp
    I can only help you with the flash file you asked for.
    If the ESL opens and the car starts then the key is doing its job I would think.
    Why its stopping after 30 seconds I can't explain.
  3. The Following User Says Thank You to Fallen For This Useful Post:
    nokwueze (28th April, 2023)
  4. #48
    i think immo problem!
  5. The Following 2 Users Say Thank You to vageric For This Useful Post:
    fred77 (4th July, 2023), nokwueze (28th April, 2023)
  6. #49
    Pls friend how can I fix the immo issues
  7. #50
    did you try the flash from Fallen in post# 45?
  8. #51
    yes i wrote the file on the bcm sir
  9. #52
    try make new key and see what happend
  10. #53
    I did and scan the car I got this
  11. #54
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by kazikk View Post
    A made a lot CAS4 and Porsche BCM and i don't think that HEX PROG is beter to read secured processor that other tools.
    I have many other programmers and prefer to use VVDI Prog for this jobs, but this is only my opinion.
    More expensive not always means better.
    true bought Mrppad XEP100 and thought brilliant at 1st but software always crashes and write back range rover doesnt work
    i could had saved my money n gone on holiday
    don't know how hex prog compares but by sounds of it inherent risk with Poshe -maybe cpu should be read out of circuit
    Solidarity with Ukraine
  12. #55
    p1et's Avatar
    Oct 2013
    Contact user @bmwspec maybe he can help you repair module if you send it to him
  13. #56
    Jun 2022
    any chance you can provide me F-flash file for BCM 7PP907064EL please. For some reason this file got corrupted - getting all FF
  14. #57
  15. #58
    Jan 2018
    Hello, can someone check if everything is OK with 5m48h pflash? After reading vvdi prog dflash, there is no communication with bcm 7PP907064GC and you can hear the relay in it
  16. #59
    Member islam kadah's Avatar
    Thank you for sharing the file, you saved my day
  17. #60
    Quote Originally Posted by brobble View Post
    I only had one 911, but it had 7PP907064HM. You can try it anyway. Maybe you get any life back to car. Unlocked means security deactivated. This makes it easier to handyle, if you need to read or write in future.
    Good luck.
    Greets MR...
