I only had one 911, but it had 7PP907064HM. You can try it anyway. Maybe you get any life back to car. Unlocked means security deactivated. This makes it easier to handyle, if you need to read or write in future.
Good luck.
Greets MR...
Good luck.
Greets MR...
amineben1992 (10th July, 2020), Hayssam1 (7th January, 2023)
ok i will try, when i write other flash dash wake up but no start !!
Off a Maccan but worth a shot.
Hope it helps.
Edit, just realised mine is 434mhz - it might help somebody else one day.
amineben1992 (14th July, 2020), Hayssam1 (7th January, 2023), p1et (12th July, 2020), raptureready (13th July, 2020)
Thanks but this File will not help me
Is Porsche dealer able to reflash BCM or they change it for new?
if you take off the oscilator to read,change the oscilator, and write a good p flash,that's the reason for bcm damage.
BTW,THIS IS 315 MHZ.
Noncense......
friends pls i read bcm 5m48h of porsche with vvdiprog to add key after writing the file back to the bcm .. the car didnt start pls here is the file
I think your flash is corrupted. I experienced this by my self. First part of flash gets erased by forcing the unlock. All BCM front dumps I have are starting with data at offset $74000. Yours starts at $78000. So there is missing some data. This is repairable by using flash from another module with same partnumber. Unfortunetly I dont have. Your car is Cayenne USA without keyless. I have 7PP907064KJ, which is also Cayenne USA without keyless. Your d-flash dump looks good.
Greets MR...
PS: Better explain what is the problem: BCM total dead or only key not recognized? BCM responds with diagnostic?
Hayssam1 (7th January, 2023), lupu_sandu (8th November, 2022), nokwueze (9th November, 2022)
the bcm is dead no respond with diagnostic sir can you repair the file sir
7pp907064em
thanks my brother the dash light came up with your file pls where can i get the file pls am grateful
Again, better explain if you want help!!! Whats means dash light came up? BCM alive (diagnostable)? Ignition goes on? Car starts? DTC´s? Is your car with ESL? Newer Cayenne´s doesnt have ESL anymore as far as I know. The US cayenne I read the file from was without ESL. But I think this is parameter in d-flash. If you have porsche piwis you can look, whether there is a frf-container (update) for 7PP907064EM or EP. I know, there are some update files for BCM Front in Piwis. So you could reflash it, if KJ is not working properly. Unfortunetly I never had 7PP907064EM or EP to read out. If you are from US, you can buy them rather cheap from ebay.
Greets MR...
nokwueze (2nd May, 2023)
thanks my brother the car dont have esl
am from nigeria
the car didnt start only key opens dash light
pls can piwis correct error
Maybe, what tools you have?
Greets MR...
