Results 1 to 15 of 25
    Sep 2013
    Default Swat Leon NEC lost key
    Friends do somebody can send pinout for pogo pin cant find as usunął on super vag key
    Sep 2013
    Please i AM far away in busches can somebody WHO have supervag send pinout for pogo pin
    Sep 2013
    4 motors odometer
    Apr 2016
    uk
    Normally is the sixth leg
    Sent from my MI CC9 Pro Premium Edition using Tapatalk
  5. The Following User Says Thank You to comizelu For This Useful Post:
    holbi1 (9th July, 2020)
    Apr 2016
    uk
    Make a closer pic with the mcu
  7. The Following User Says Thank You to comizelu For This Useful Post:
  8. #6
  9. The Following User Says Thank You to paul_12345 For This Useful Post:
  10. #7
    Sep 2013
    This one is nec
  11. #8
    what part number from the back of cluster?
  12. The Following User Says Thank You to paul_12345 For This Useful Post:
  13. #9
    Apr 2016
    uk
    This should be!
  14. The Following User Says Thank You to comizelu For This Useful Post:
  15. #10
    Sep 2013
    This from advanced is bit diferent
  16. #11
    the pdf shows you which pin on the NEC to probe.. number 67
  17. The Following User Says Thank You to paul_12345 For This Useful Post:
    holbi1 (10th July, 2020)
  18. #12
    Apr 2016
    uk
    What?
    Try the one I sent you
  19. The Following User Says Thank You to comizelu For This Useful Post:
  20. #13
    Sep 2013
    Can you point where is this pin please
  21. #14
    Sep 2013
    This Is back from odo
  22. #15
    pdf says 67 which would be the right hand side of resistor marked 272.
  23. The Following User Says Thank You to paul_12345 For This Useful Post:
