Results 1 to 7 of 7
    italy
    Default VW GOLF 5 VISTEON CLUSTER SWAP WITH USED ONE. TMS DEAD ONLY EPROM 95160 CAN BE READ
    Hi friends of DK.
    i hope thet you can help me.
    i've a golf 5 with visteon cluster.
    cluster it's dead. internal TMS have a shortcut.
    i usually can swap with used cluster with AVDI read PIN ,MAC CS ecc and copy to used cluster immo data.
    but in this case i can't read immo data with diagnostic tool.
    my question is:
    there is a method wich i can found immo data to write in used cluster?
    i can read oly eeprom from old cluster
    Oct 2014
    Netherlands
    Hi, if you read eeprom of cluster then you can extract most immo from it using some public available tools (Visteon_95160v2.4.exe).
    You can also post here and member will help.
    The only missing info will be MAC.
    If you are able to log canbus (on ecu or cluster, not OBD) then you can retreive MAC there.
    Or you can read immo from engine ecu. Can you tell what type of ecu you have?
    Rgs H2Deetoo
  3. The Following 2 Users Say Thank You to H2Deetoo For This Useful Post:
    fra69 (13th July, 2020), immoneard (12th July, 2020)
    Jul 2019
    Post eeprom form Dash and ECU and write what ECU it is .
    italy
    thanks for reply.
    i'have not here car.
    i've only dash, i found program thet you said,now i ask to my customer if he bring to me ecu for read mac data.
    when i've all i post it.
    many thanks for help
    Jul 2019
    In mean time post Dash eeporm .
    italy
    here my dump.
    in attachment see data from ecu and cluster eprom.
    tomorrow i try to program new cluster with this data and tell you whats happen.
    thanks for help
    Oct 2014
    Netherlands
    If you copy immo data (correctly) to donor VDO cluster it should all work.
    Note that maybe some swapping of bytes is needed depending on the tools you use!
    CS: 366B806C0F9CA6
    PIN: 06655
    IMMOID: VWZBZ0E0305220
    VIN: WVWZZZ1KZ6W146584
    MAC: 47700012
    KEY1=B310BAB0
    KEY2=B310C6AC
    (B3 is MSB byte)
    If you have problems making it work then post here your new immo block.
    Rgs H2Deetoo
  9. The Following 3 Users Say Thank You to H2Deetoo For This Useful Post:
    fra69 (14th July, 2020), immoneard (14th July, 2020), vampirelo (20th May, 2022)
