Results 1 to 9 of 9
    V.I.P. Member biffo1's Avatar
    Mar 2008
    Default How To: Update Firmware, Debranding, and/or Change Language Pack on the Nokia N95
    i thought this might be usful , ive used it works a Treat Here
    [CENTERhttp://i195.photobucket.com/albums/z39/biffo1/iOS-4322.jpg[/CENTER]
    V.I.P. Member allycoops's Avatar
    Feb 2008
    Behind Enemy Lines
    this work on teh 8 gig as well as original one?
    I'll check it out later ,
    thanks biff , no time at mo.
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Would be good if the software and guide were on here but thanks for the links biffo, I'm sure loads of people will want this.
    Mar 2008
    will see what i can do fellas
    May 2008
    biffo ,
    I try it nice guide. But Nemesis Service Suite did not support changing product code for N82. Will you try it on N82 and give me result.
    Newbie Seedy_r0m's Avatar
    May 2008
    Remember folks, if you're upgrading the firmware on your N95...DO A BACK-UP FIRST.
    I made the mistake of not backing mine up, and lost the activation key for the preloaded Spiderman movie, rendering it useless
    Apr 2008
    thank you very much
    May 2008
    Debranding is a must for N95 users. The battery time will double and the gps connects far quicker mine now connects in under 10sec. The newest rev is out now V20.0.016 read mixed reviews so far though, i am still running 20.0.015. Any body on the new version?
    DK Veteran daz24c's Avatar
    May 2008
    Stockton on Tees
    ill give it a try and see thanx
