Results 1 to 7 of 7
    May 2020
    Default Volvo edc16c31 problem!
    I have volvo v70 with edc16c31 ecu.
    After tune and egr/dpf delete the car is acting up.
    After 5-8 minutes the car dies and i need to pull out the key and put i back and the car is fine again for a few minutes. I did get this car cheap becouse of this problem.
    I know that the ecu has been replaced næand the problem did start after new ecu was installed.
    Can this be a immo problem?
    Someone maybe have some ideas?
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    With ori file ok, and no issues...?
    May 2020
    Havent tried yet, need to deaktivate dpf ang egr in ori map
    figani's Avatar
    Feb 2018
    Try it...
    If it's OK with ori...
    Then you know where you issue is located...
    May 2020
    If its acting same then its a mekanic problem?
    figani's Avatar
    Feb 2018
    Quote Originally Posted by Mauiii View Post
    Maybe,....
    But if it's all ok with ori, then you know that your modification is fault...
    Jun 2017
    If the problem started with replaced ECU, well...
