Results 1 to 7 of 7
    Jan 2018
    south africa
    Default opel y17dth pincode
    hi can somebody please help with pincode from dump opel yd17th denso 93c86 eeprom
    May 2020
    tot557545@gmail.com
    hi not read good eeprom...... File data error.
  3. The Following User Says Thank You to ecuprogramer For This Useful Post:
    jacques23 (12th July, 2020)
    Jan 2018
    south africa
    hi i read with upa as 8bit must i try as 16 bit thanks in advance
    Bllinda's Avatar
    May 2010
    Baltic
    There is no pin here. Read.bcm....
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  6. The Following User Says Thank You to Bllinda For This Useful Post:
  7. #5
    Bllinda's Avatar
    May 2010
    Baltic
    Or inmo.box ....
    Quote Originally Posted by Bllinda View Post
    today
  8. The Following User Says Thank You to Bllinda For This Useful Post:
  9. #6
    Jan 2018
    south africa
    hi its for ecu replacement so cars original pin wont work need replacement ecus pin too reset ecu and then program with opcom original pin i already pulled from old ecu its at line 50 1 and 3 this dump only alphabet numbers at those lines
  10. #7
    Aug 2018
    East Pole
    Quote Originally Posted by jacques23 View Post
    Read it like 16bit
