Results 1 to 8 of 8
    Mar 2019
    Earth
    Default PASSAT B6 ESL FAILURE ,PROBLEMS ON PROGRAMMING
    Hi guys.I m working on a 06 Passat b6 1.9 TDI with failure on esl.Basically when i got the car the ignition won t turn on and the yellow steering wheel would come on the dash also no comunication with imobiliser.
    I got a used elv from scrap yard,installed.Now the car turn on ignition and i get comunication with immobiliser.I got the pin from engine ecu with FVDI (EDC16U1) ,checked the pin by log in on ecu and the ecu accepted the pin .But when i log in on the adaptation on immobiliser it says pin is not good and i have wait time 250 minutes.
    Now the question comes : Can i just swap the MCU or E2P (i don t really know what it has inside) and put it from old esl to "new" esl ? Does all the esl has the same mcu or e2p ? The esl is the same manufactuerer year as the old one.Thanks
    Aug 2013
    Macedonia
    Buy new esl from dealer install in vehicle and adopt with pin code from car use vcds
    30 min for installation 5 minutes for programming
    Mar 2016
    ireland
    nenadgorgi is correct you cant adapt a second hand one only new from dealer .....
    Mar 2019
    Earth
    I ve seen people adapt second hand units. What about swaping the mcus?
    Mar 2016
    ireland
    thats making extra work for yourself .... its a 40min job with new esl from dealer......
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by 12manux View Post
    Don't confuse programming with a detail that's just changed places........learen.gif
    Mar 2019
    Earth
    Thanks for infos guys (or maybe not). SOLVED by swaping the mcus. Car started right up from first try.
    Thanks all for replies.
    ricked's Avatar
    Apr 2016
    Europe
    next time make copy with xprog
