Ori read-bad eeprom. Read immodata from dash
Hello to All...
I´m trying to solve an issues on a 2017 VW Vento that had some ECU problems and i need some help...
Original Car ECU: 03C906014GB - 7GV CLSA
The ECU had some internal pins damage and it seems that for some reason it f$%&#ed things up on the Eeprom 95320.
I have a donor ECU and i made some tests:
Swapped Eeprom from Original ECU to Donor ECU and didnt worked.
I was able to Fix Original ECU Pins, made some testes and have same result when testing Donor ECU and Original Eeprom
Another Test: Donor Eeprom sawpped into Original ECU: Immo Active (Ecu seems to be working but eeprom is from donor, so it wont work)...
Now, i read eeprom on external programmer and Original ECU Eeprom seems to be all wiped out (or its just got fuc#$%%ed up)
Read Donor ECU Eeprom and it seems all OK (but wont work on this car).
Can anyone tell / help me if i read Dash eeprom, we will be able to "fix / mod" eeprom so that car can start?
If anyone can help me out i will really really appreciate...
In attached you can see reading from Original ECU and Doner ECU eeproms
Edit: Just Added Dash Eepro read. If anyone can give me CS and PIN i would appreciate
Thanks guys...
Just Consider helping Freely like I want to do...
Thanks and Rep are Always Welcome...
boxsport (12th July, 2020)
It is not possible to extract Immo data form this cluster by eeprom. You need to read it with VVDI2, AVDI, SMOK by Obd. This is cluster with Nec 24c64.
boxsport (13th July, 2020)
Hello again.
I just tried once more and it seems that my fvdi unit, using VVDI2 soft connects to the dash but i´m always getting the message "please insert a working key" and nothing happens...
Can anything be done with the tools i have?
using vag loader V24 i cant enter in "service mode". i try to enter and it gives a message that "enter bootmode OK" but then a error mesage pops out: "Unknow Dash Type"...
is there anything i can do?....
try read vvdi2 in service mode
I do not think you will be able to do anything with tool you have , this is very new dash and VVDi2 loader you have or FVDI is to old for this .
hello guys...
so, i was able to have someone with an original VVDI2 to come and see if he could read the dash, and, no luck....
apart of the "original" way with ODIS, how could this dash be read?
i bought a VAS5054a unit but it will take some days to arrive...
Maybe to correct .........how to kill a dash?!.........
If you see that just nothing, maybe it's time to finish this show and send the car to the dealer?.......thinking.gif
NB!!! Don't ask in PM old file password , Im not remember.
With Odis Online you should be bale to do this .
Can you help me out modifing the ECU Eeprom bin so that i can use it?
Car VIN is: MEX5H260XJT102401
VW Vento_2017_Magneti Marelli_7GV-CLSA_95320_Donor ECU_Ori Read
CS: 3C 48 C1 FF 86 51
LOGIN: 61504
VIN: MEX5H260XJT102401
boxsport (24th July, 2020)
