Results 1 to 8 of 8
    Oct 2016
    Default Help CAS3 + Mini One R57N
    Hi guys, can someone help me check if the CAS3 of a Mini One R57N is damaged or not? The eeprom and the flash seem correct but the car does not start.
    Someone could check if the CAS is ok
    DTC CAS: A0A9; A0AA
    61.35-9221719-01
    C4 20.8 09 06A0
    5WK4 951CBR
    MCU MC9S12XDP512
    OL15Y mask
    Thanks in advance
    Sep 2014
    UK
    Looks good to me, i think processor dead. try replace it with another cas unit?
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by daten View Post
    DTC CAS: A0A9; A0AA
    61.35-9221719-01
    C4 20.8 09 06A0
    5WK4 951CBR
    MCU MC9S12XDP512
    OL15Y mask
    Thanks in advance
    it's a common error after downgrading the cas3 firmware. Update to the orig or higher version and you will be fine.
    And use the search button...
  4. The Following 2 Users Say Thank You to jodge For This Useful Post:
    Hayssam1 (27th March, 2023), igorr (13th July, 2020)
    Oct 2016
    Quote Originally Posted by jacek77 View Post
    Thanks for your help. I have not tried with another cas unit but the interesting thing in this case is that on the table connecting by pinout there is communication with the CAS module. Ista D does not detect the vehicle. Is the ELV unit possible? The other observation that makes me think that there is a fault in the processor or some solder on the CAS board is that if the car stays in the sun for a while and the dashboard warms up, the car does not start.
    Thank you
    Oct 2016
    Quote Originally Posted by jodge View Post
    Thanks for your opinion. I doubt it could be the subject of programming. The symptoms of failure started from less to more when the vehicle is exposed to the sun and the dashboard is heated. Taking into account the location of the cas module in mini R57, I think that the high temperature caused this failure and in the cold the car started until it stopped starting completely.
    Thank you
    jodge's Avatar
    Mar 2017
    Thank you
    hemm it's an locksmith forum my first thought is a programminig attempt. Obviously
    and the DTC's are the same like the errors after dowgrading
    Nov 2021
    Hello everyone
    Would someone have the pinout for the MC9S12XDP512 MCU with UPA?
    https://t.me/pump_upp
    post dump from cas hier.
