Try this pinout
Try this pinout
I used this pinout see the pictures. Read is good write dont start.
some edc16 need immo to start write ....on VAG edc16 ecus with immo active the write will not start on obd bench 100% maybe for this alfa ecu too...
Autotuner- Kess - Ktag, genuine master tools.
gmendieta (14th July, 2020)
You could try and remove immo eeprom and try and write then if it works resolder eeprom
This ecu does not work on bench because needs read immo.
Works good on obd, with mpps and galleto v54.
Tested many times!
Enviado do meu Mi Note 10 Pro através do Tapatalk
i have only ecu. i dont have key. How can i take the car and write mod file and immo swich off?
You need to do BDM mate
