have you read the ecu from pinout or from obd socket?
To make the correct immo off it must be read/write in boot , otherwise it will not write the complete changes.
I removed the flash and red it with the programmer
immo U1600 OFF
pas pm
alejandroo (15th July, 2020)
I didn't get the password, can you send it one more time.
Still need help with this car.
Thank you!
press buttons
https://mega.nz/file/dyJjXYjD
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
Hi kiszka, with your file the car starts, runs fine with no fault codes, but after a few minutes of driving the engine lamp comes on without any fault on the engine. If I turn engine of and start it again the engine lamp goes off for a couple of minutes and then comes on again.
Any ideas
make eeprom virgin....................
need help
now my goal is to buy xp-005
who will help?
problem solved!
with kiszka's flash file and virgin eeprom car works fine without any faults and engine light off.
Thanks Named25, kiszka and rafal for help.
por favor necesito la contraseña t un caso con una ecus nro 0 281 010 931 944 si este archivo corrige el problema estaria mu agradecido por favor envieme la contrseña muchas gracias d antemano
[QUOTE = alejandroo; 3913430] Quité el flash y lo rojo con el programador [/ QUOTE] por favor si m puedes pasar el pass
