Results 1 to 7 of 7
    Aug 2016
    Default problem program remote toyota chr
    hello
    i want program remote for toyota chr 2018 orginal key chip 8a normal key i genrated new key with keydiy but i can't enter programing mode with obd(lonsdor and x300 dp) and can't program it manual
    1.Switch the ignition ON and OFF.
    2.CLOSE and OPEN the drivers door TWICE – so door ends up in the OPEN position.
    3.Switch the ignition ON and OFF.
    4.CLOSE and OPEN the drivers door TWICE – so door ends up in the OPEN position.
    5.CLOSE the drivers door.
    6.LOCK the door using the door lock button on the door.
    7.Switch the ignition ON and then OFF.
    8.UNLOCK using the door lock button on the door - the locks will cycle to indicate programming mode.
    9.Remove key from ignition..
    how can program this remote manual and can generate with keydiy or xhorse?
    ray-ray's Avatar
    Nov 2009
    That is a type 2 remote system same as (Camry,Corolla,the net,Tacoma. And so on...
    Aug 2016
    hello
    how can program new remote manual or with obd ?
    ray-ray's Avatar
    Nov 2009
    No manual process via obd2 only.
    Aug 2016
    but i tried with lonsdor and x300 can't connect to car or maybe must use orginal remote because i tried with keydiy remote
    Apr 2021
    Quote Originally Posted by jihed aissa View Post
    I face aa same problem , are you slove it?
    I try with xhorse pad also filed to login even same other car is login normaly!!!
    autochei's Avatar
    Mar 2013
    romania
    zedfull can do remote type 1
