Results 1 to 8 of 8
Thread: GMC envoy 2003
    Top Poster MasterCodein's Avatar
    Oct 2018
    Jupiter
    Default GMC envoy 2003
    Hello folks,
    Anyone could upload a picture of the back of the connector of a GMC envoy 2004 please.
    I need to compare with that one.
    Thanks/Merci
    Sent from my Pixel 2 XL using Tapatalk
    clusters's Avatar
    Mar 2015
    Canada
    Compare for what? That board looks fine.
    What is your problem?
    Oct 2018
    Jupiter
    It came short to ground with a consumption of 10mA.
    clusters's Avatar
    Mar 2015
    Canada
    Well the connector pins are not your problem, and a 10mA draw is not a short to ground.
    Post a clear pic of the whole back of the board.
    Oct 2018
    Jupiter
    Here it is.
    clusters's Avatar
    Mar 2015
    Canada
    Not hi res enough.
    Look for grey spots around the vias to the ground plane.
    Oct 2018
    Jupiter
    Ok I will.
    Oct 2018
    Jupiter
    I fix few via that had corrosion but that didn't help anything.
    Possible to have some point of reference on the board so I can check voltage? Maybe with the amount I should get at some area on the board so I can eliminate few areas?
    On Q17, Q20 and Q18 I am getting around 9.6 volt on each legs
    Thanks/Merci
