Here new.....
Here new.....
zorans (16th July, 2020)
Thank you brend,
it working. Which calculator you use?
momogsm (17th July, 2020)
Thank you my friend. I understand first row but anothers not.
Please I'm puzzle you're not using a scientific calculator.
if anyone have UPA & needed a scripts
copy - paste - to ( ELRAsoft - UPA-USB suite - Device Programmer or Device Programmer-s )- DeviceScripts
reason for edit:- the script has an error in verify after correction. it'll show crazy km! but it doesn't affect
the 'Read KM' & 'New KM'. That can be corrected . If needed me to correct it just post it in this tread otherwise
I presume no-one interested.
cjawahir (21st July, 2020)
Hi bender,
I already try you calculation what is in your script in upa but it is simple calculation (desire/32 => hex, swap and inverse) and it is not work. Than on dashboard I have not mileage!!! Are yuo try this solution on some car?
It is not So simple. What about edition for mileage count up?.
However with my script is easy to fix it
with my Orange 5 calc is very easy to fix it
I'm not quite understand you. Just copy & paste to the appropriate folder. but you must have upa soft or already have upa soft in your pc.
if you do not have upa , it's still possible but im not going in detail. after you copy & paste it'll be as follow in the pictures I attached here
you will not get that extra drop down menu as i did not add in the extra here. only read & write new km
The script is not limited to CRV but it expandable to other models or sometime different makes too & pictures, instruction of cluster
removal etc etc.. can be added. See the drop down menu.
I respect all the other who have better script but if you find mine hard to use well at least you can
try while other just pictures.
