Results 1 to 15 of 21
    Portugal
    Default Boot pin and GPT for ECU me17.9.52
    Hello guys
    I'm trying to connect a citroen C1 ECU BOSCH 0261S10407 Toyota-0H400 that as inside a Tricore TC1782F-320 that I need to read. Does someone knows the connection for boot pin .
    Thank's in advance
    Portugal
    BUmp! And GPT too
    Portugal
    Bump this thread up.
    Portugal
    Does anyone as the password file for this ECU?
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by JotaB View Post
    Hello guys
    Thank's in advance
    here you go...
    press buttons thanks and reputation...
  6. The Following 3 Users Say Thank You to figani For This Useful Post:
    Carceaion (16th May, 2022), JotaB (20th July, 2020), vari (2nd April, 2024)
    Portugal
    Quote Originally Posted by figani View Post
    here you go...
    Hi Figani
    Thank's M8
    You know how it is when we are striving for some information so anywhere, anyone who can help me is welcomed.
    In your PDF just boot and cnf1 and it's for toyota mine is for citroen C1 1.0 12V. Can you enlighten me if there is a need for GPT pins. Because I don't know if it is password protected. Those pins are always the same for the TC1782. I've tried it and no success in reading the eeprom using PCMflash for BSL TC1782.
    BR
    figani's Avatar
    Feb 2018
    Hi Figani
    Thank's M8
    BR
    I donŽt think that youŽll handle by pcmflash and booting...
    better try by service mode module 71...
  9. The Following User Says Thank You to figani For This Useful Post:
  10. #8
    Portugal
    Don't have module 71 in PCMFlasher 1.99-2. And with KTAG HW V7020 SW 2.25 will it be possible
  11. #9
    Portugal
    In your PDF A81 is in my ecu the pin for the clutch switch. Mine is different and the GPT as I've studied is for PWM of Crankshaft and camshaft right?
  12. #10
    Portugal
    Found the module 71 but no luck . GPT just functioning in that module in module 53 they do not work ?????
  13. #11
    Portugal
    Do you have the gpt pinout for Citroen me17.9.52 not for toyota. Thanks in advance!
  14. #12
    figani's Avatar
    Feb 2018
    its same, and before start to search longer...
    open this ecu and post a good photo tc...
  15. #13
    Portugal
    I've checked with all the other car models Aygo, C1, 108 for the GPT the pinning is always the same.
    Well I'm wondering if someone as the password file in backup. that could that do the trick in BSL mode??
  16. #14
    figani's Avatar
    Feb 2018
    what and why did you solder their....?
    from where did you get this pinout...?
  17. The Following User Says Thank You to figani For This Useful Post:
    JotaB (21st July, 2020)
  18. #15
    Portugal
    Man I've made a big error those are not the right pins. Where the hell was my head going. I'm going to correct it and see if now it reads
