here, i removed the protection so you can keep your tuned file and did DPF OFF
You need to unplug:
-Differential press. sensor.
-Temp. sensor after KAT
-Temp. sensor before DPF
pass in PM
Good day,
EDC16CP34 3.0L V6TDI 8E0910401P 0281013191
Hello, I'm trying to turn off DPF on my A4. Reading the file via OBD was not successful even after several attempts and using different devices. Finally I read the ECU via BDM (ORI file). The first problem occurred that the car was modified and the editor locked the file so that it could not be opened in WinOLS. So I found the original file for my A4 (A4 file) on DK and turned off DPF on it, to turn off DPF I set the 8-bit address 1D16C4 to 0 and made a Checksum (DPF off file). Subsequently, I uploaded the map back to the ECU but the problem still persists and VCDS writes error 009263 - Particulate filter excessively clogged
Can anyone help me turn off DPF? It would be best to turn it off on the edited map from the ORI file to maintain performance, but if it can't be edited, you would help me edit the map from the DPF off file. Well thank you
You need to unplug:
pass in PM
Andytech3 (19th July, 2020)
Hello please send me pass for this file . thanks
