Results 1 to 4 of 4
    Default EDC16CP34 Audi Q7 problems
    Can somebody please, help me to solve problem with these ecu:
    0281013691
    EDC16cp34
    I got problem U0301 software incompatible
    Somebody deleted DPF and i tried all sensors disconnected but DTC present.
    Car stales over 3000 RPMS and RPM drops to minimum, after depressing accelerator pedal and pressing again it goes to 3000 RPMS and drops again.
    File found in ecu attached:
    Does somebody has similar problem?
    Thanks for help!
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Hi.Flash this one.Do You disconnecteted all sensors a mean differential pressure also and all 3 temp sensos?
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
    Thanks my friend!
    Unfortunately now i got problem still present with stalls over 3000 RPMs.
    I even remove and flaps (not physically)
    Does somebody had something similar?
    Thanks for your help
    carbon7319's Avatar
    Aug 2011
    Macedonia
    In your file is not just DPF off but someone try to make some extra power.
    I restore all modifications exept DPF off and i made U0301 off.
    Good luck.
    Just DPF off.rar
    cheksum not corrected , let your tool to do
  5. The Following User Says Thank You to carbon7319 For This Useful Post:
    tihiuvek (3rd August, 2020)
