Results 1 to 11 of 11
    May 2017
    trowbridge uk
    Default Ktag not working in bdm
    Hi I got ktag clone and is not working in bdm I tried 4 different ecus and few different chargers and always getting hardware configuration not supported . I done few ecus in boot mode edc17 and that’s works perfect but not in bdm even don’t recognise ecu . I tried edc16c9 Iveco , edc16c39 from Saab and Zafira and Med9.1 from vag . I use bdm frame and direct connection . Will anybody know any solution or suggestions? Thanks in advance
    galiza's Avatar
    Jun 2011
    It usually works well. Maybe bad clone (need rework) maybe wrong connection. Can you post pictures about connection on EDC16C39?
    It is better to arrive 10 minutes early, than to be bored all the way.
    May 2017
    trowbridge uk
    Quote Originally Posted by galiza View Post
    With bdm frame and without using cable what ktag said . No problem with connector on boot mode with edc17cp14 done few
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by Slav1984 View Post
    just take a look at your photos...
    on one photo and on other photo...
    you hold the bdm cable around 180 degrees...
    12V and ground are going through this lines...
    if you really had contact with pads on pcb...
    then dead, asta la vista, good night, tod, and so on....
    May 2017
    trowbridge uk
    Picture taken just to show was connected when was reading with ktag manual
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Post a clear photo of adapter, to see if you use the correct one...
    galiza's Avatar
    Jun 2011
    Quote Originally Posted by figani View Post
    Yes, I think so, the BDM adapter is turned 180º (at least It doesn´t match with gallo´s manual) so......
    May 2017
    trowbridge uk
    I just put that quickly for picture when I connect I always have wright way like ktag say . I send it to get exchange was faulty unit
    i had same issue and turned out to be ac adapter it is 12v 2a soon as i used a 14v 2a adapter worked fine
    May 2017
    trowbridge uk
    Quote Originally Posted by djsy2004 View Post
    I tried that I use now 12v 4a and still not working I send it to get exchange for new 1 hopefully will work when then replace it
    May 2017
    trowbridge uk
    ProbleM solved ktag got replaced all working fine
