Try other files, most of "erom_vvdi" are same.
Manta1600 (1st August, 2020)
Yes you are right.
Custumer key is 4H0.959.754 K with pcb .111
I had and tried to program 4H0959754DD and 8K0959754H with pcb - .211 - not successful
After that I bought 4H0.959.754 K but inside was again .211 (maybe someone swaped the cases) I tried to renew it with .111 files but the key can't be read - I renewed with .211 and key looks OK but yesterday I tried on the car and the key can't be accepted
so I think the same that you wrote - if original key has PCB .111 you must program key with PCB .111 - if is .211 must use key .211
I ordered again 4H0.959.754 K and hope that this time will receive key with PCB .111
yes but maybe original key is also .211
I tried many times with few different keys all .211 renewed with different files Baracuda - VVDI prog - KD - always not successfull
I tried to program the keys with VVDI2 and Autel - Make dealer key - OK - progrm key - key can't be accepted - The original key always is accepted
so I think that if original key is .111 is not possible to program key .211
next week I will try again if I recive the right key
I ordered 4H0959754K key from ebay and the seller sent me picture from PCB inside - again .211
Looks like is hard to find .111
no, she is present
someone have firmware for keyless 315 and hardware xxx....111?
8T0959754G 111-06
Today I renewed 3x 8T0959754D with VVDI prog. Everything was fine. Only 1 of the 3 keys work. The other 2 are dead. They were working before the renovation.
Has anyone encountered such a problem? Any chance to save them?
Wrong files
look careful the pcb
write again the right files and will be ok
The keys have PCB 233.453.011-02
Does anyone have files for such a PCB?
